Kitchen Sink Extension - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2012, 08:47 PM   #1
Rewards Points: 18
Kitchen sink extension
So today I looked under the sink of a house I'm renovating. I noticed a glob of plumbers putty where the drain extension comes out from the wall. I removed the sink and when I did I noticed at some point in time someone jammed a pipe into the drain in the wall. Basically a slip joint and for the sill they used plumbing putty. It looked like it has leaked multiple times. upon further inspection it looks like the drain extension broke off at some point and the old drain appears to be soldered. I'm at a loss where I should go from here. I'm including a picture to help illustrate the problem.
P.S. I also removed a bit of drywall so you can see better.
fuzzbutter is offline   Reply With Quote
Old 04-29-2012, 09:32 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
Is that lead pipe? If so, you'll probably have to rebuild the tee and drain line. Working with lead is beyond most homeowners.
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (04-29-2012)
Old 04-30-2012, 06:36 AM   #3
If that was an old drian(1 1/2 or 1 1/4) it is porbably not soldered, threaded into an iron elbow or tee. It will just seem that way since it has been there for a LONG time. It will be very difficult to remove and cap, assuming that is your goal. An inside pipe wrench might work????
Tags
broke , drain , pip , sink , solder
Moving kitchen sink teachtech Plumbing 4 08-08-2010 10:13 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
