Kitchen Sink Drip - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 10:03 AM   #1
I day I will FLIP!!!
Kitchen sink drip
Hi all,
Hope you can help me! I have a plumbing issue that my husband (nor I) can figure out. We have a constant drip on our single-handled Delta kitchen faucet.
What is the easiest way to fix this or what should we look for first?
TIA
flipper2b is offline   Reply With Quote
Old 07-25-2010, 12:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A Delta has a ball valve under the dome under the handle that operates over a hot and cold set of two rubber-tip seats on springs. The seats and springs are usually what wear out and have to be replaced from time to time.
You may be able to stop the drip for a time without having to replace the seats and springs yet by adjusting the pressure of the ball onto the seats.
You don't have to turn the water off for this adjustment.
Remove the handle with an Allen wrench-that-fits to loosen the recessed set screw and pull the handle up off of the stem of the ball.
There will be a plastic ring with either two or four small notches in it around the inside of the dome cap. Stick the ends of pair of needle-nose pliers into two opposite notches and turn the plastic adjusting ring clockwise with the water turned on. When it stops leaking (hopefully), you should be OK for a while. If it doesn't stop leaking, then you will have to replace the seats and springs, which are readily available at most any plumbing supply, hardware store or big box.
It's easy, and we can tell you how when you need to.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 12:01 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
