Kitchen Sink Drains To Sump Pit - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2011, 03:38 PM   #1
Rewards Points: 491
kitchen sink drains to sump pit
Hi,
We have recently bought a 55 year old house in Louisville, KY. It's a ranch house with a finished basement. I discovered that my kitchen sink upstairs drains into the sump pit in the basement. (And I'm guessing that the dishwasher, too.) We have a kitchen and a bathroom in the basement, but they DON'T drain to the sump pit, so it is especially puzzling why they connected the upstairs kitchen to the sump.
Neither the seller not the inspector mentioned this. Is this even up to code? The sump pump dumps the water onto the driveway.
As for who is responsible, if it is not up to code: I'm guessing I'm on my own. We have lots of expenses with the new house, so I really don't want to run into another thousand dollar repair. I'm pretty handy - is this something I may be able to tackle myself?
Thanks,
csab_ is online now   Reply With Quote
Old 08-16-2011, 07:17 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,... I'm guessin' yer Right,...
Plastic plumbin' ain't too awful hard,...
Have ya got enough drop, 'n a sewer pipe close by to tap into,..??
Old 08-17-2011, 08:16 AM   #3
DIY staff
Rewards Points: 7,174
Post some pictures-----My guess is that the original piping clogged up and they made a quick 'temporary' fix----and then lived with it forever.
csab_ (01-08-2012)
Old 08-17-2011, 11:35 AM   #4
Rewards Points: 3,130
In many areas it's legal to discharge gray water directly to the ground. But even if legal, I sure wouldn't want it dumping on my driveway.
Old 08-17-2011, 03:12 PM   #5
Rewards Points: 491
Thanks for the responses! I will have to take apart the kitchen sink cabinet to see where the pipes are. I can see where the sewer pipe is coming down to the basement and it doesn't seem to be far from the kitchen sink. I'll post some pictures later.
Thanks,
The Following User Says Thank You to csab_ For This Useful Post:
oh'mike (08-17-2011)
Old 01-08-2012, 06:24 PM   #6
Rewards Points: 491
Update: We finally got this fixed. All in all we had a lot bigger job done, which included the installation of a backflow preventer valve, but the Sewer District paid for a good portion of the cost. At the end we only paid ~$500. (And I'm trying to get the previous owner to pay this.)
So oh'mike was probably right. We found the old drain in the ground, clogged and partially fallen apart. The plumbers connected the kitchen to a drain under the slab that I would have never found (but the guy figured out where it must be). I'm glad I didn't do it myself. The work itself is not too hard, but the plumbers knew all those (somewhat arbitrary) regulations, and of course I didn't have enough exprerience to find that drain pipe.
I cleaned the sump pit, which was super disgusting after about 10 years of kitchen water being collected there. Since the water table is way below our house, I have zero accumulation water in the sump pit now.
I'm so glad it's done. I also learned a ton of things about plumbing.
The Following 2 Users Say Thank You to csab_ For This Useful Post:
oh'mike (01-08-2012), TheEplumber (01-08-2012)
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Help moving kitchen sink pflaxman Plumbing 2 09-22-2009 12:19 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 05:59 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
