Kitchen Sink Draining Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2015, 02:54 PM   #1
Rewards Points: 2
kitchen sink draining issue
I am having a problem with my kitchen sink draining. Whenever I drain a large amount of water i.e. dishpan full. I hear water splashing in the basement. when I went to check there is a y shaped joint in my pvc pipe. There is what looks like a cap with a small hole in it and the water is spurting out of it. It is a manufactured hole not a crack or anything like that. I have zilch knowledge of plumbing. Is there supposed to be an opening in this cap or should it be replaced with a solid cap. I know that cap is probably not the correct word, but the y shape looks like another pvc pipe should join in there but there is no additional pipe to join to, so I was guessing that it is there to stop water from spurting out. Can someone shed some light on this. Thanks
mrose821 is offline   Reply With Quote
Old 03-29-2015, 06:17 PM   #2
Rewards Points: 13,450
It's anyone's guess what it is without a picture.
Old 03-29-2015, 06:49 PM   #3
Sounds like you're describing a cleanout. You remove the cap and snake the line from there if it's clogged. There is no other pipe that goes there. Why someone put a hole in the cap, idk. There should not be a hole in it. Maybe a venting issue?? Just guessing.
Please post a picture when you can. Thanks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
mae-ling (03-29-2015)
Old 03-29-2015, 08:09 PM   #4
Rewards Points: 2,210
Does it look sorta like this? maybe different color and size. If so you should be able to just unscrew the plug and get just that from a good lumber yard or plumbing place.
http://www.terrylove.com/images/home...chanoid_03.jpg
mae-ling is offline   Reply With Quote
Old 03-31-2015, 09:19 PM   #5
Rewards Points: 136
I would have to agree that the hole got put in there for a venting issue, but will add that if you have water squirting out of the hole, you have a blockage in the line. A free flowing drain to me does not make water leak out of a properly installed cleanout. I would remove the cap, snake the line and put a new cap in. If you have a vent issue, they make a mechanical vent you can plumb into the cabinet space under the sink.
karin els is offline   Reply With Quote
New kitchen sink issue Grebus Plumbing 2 01-21-2016 10:22 AM
Kitchen sink not draining, is it the vent? gdav Plumbing 18 02-12-2013 03:38 PM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
kitchen sink gargles when washer is draining Tonglebeak Plumbing 38 02-24-2010 12:43 AM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
