Kitchen Sink Drain Slow Draining Because Of Air Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2011, 08:00 AM   #1
kitchen sink drain slow draining because of air flow
recently added a air flow to exciting plumbing work for a while but now it takes over night to drain. what could the problem be? I know it's not clogged.
102344 is offline   Reply With Quote
Old 10-24-2011, 09:49 AM   #2
jburd964's Avatar
Rewards Points: 166
What is air flow?
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 10-24-2011, 01:19 PM   #3
AlbacoreShuffle's Avatar
I'll bet it is !
AlbacoreShuffle is offline   Reply With Quote
Old 10-24-2011, 02:15 PM   #4
jburd964's Avatar
Rewards Points: 166
Get you a shop vac, suck pipe dry, if it's plugged it'll open. Then fill both sinks and open both if it runs good if its something else you'll know.
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
Clogged Kitchen sink drain hornsby Plumbing 2 07-23-2009 09:46 PM
Slow kitchen drain - tried almost everything! Critical Mass Plumbing 17 07-15-2009 07:57 AM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
