Kitchen Sink Drain Reverse Osmosis Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 11:20 AM   #1
Rewards Points: 366
Kitchen sink drain reverse osmosis connection
For reference, see the kitchen drain photo in this PDF:
http://dlshare.s3.amazonaws.com/temp/sinkAndLaundry.pdf
There is a reverse osmosis water filter system installed, and there's a red plastic flexible hose from reverse osmosis water storage tank (like a small gas tank) that pipes into the drain (didn't know those systems have such connection?)
My question is, I just got the house and if I don't plan on using reverse osmosis system anymore, do I need to cap off that drain connection where the red valve is? What would I use to cap it off? Some links / reference photos of what to cap off with would be nice.
Or better to replace the drain pipe connection right there with one that doesn't have a connector for reverse osmosis instead? Might be good idea as drain is a bit dirty.
But wanted to see which is simpler, cheaper, and/or better solution.
daluu is offline   Reply With Quote
Old 01-31-2012, 05:16 PM   #2
Rewards Points: 636
in my opinion after seeing picture it would be wise to change strainer basket and tail piece at same time make sure you unhook osmosis if you take out drain/flush hose
jaydevries is offline   Reply With Quote
Old 01-31-2012, 05:51 PM   #3
Rewards Points: 14,312
I agree it all needs to come out.
Anytime I see one of these installed I know there's something wrong with the water.
Have it tested. May be as simple as adding a water softner.
Old 01-31-2012, 06:32 PM   #4
Rewards Points: 366
Joe, you mean test the water? And it might be hard water containing mineral deposits?
Also, when you say see one of these installed, are you referring to having reverse osmosis filter (plugging into drain plumbing) OR just having any water filter installed in general?
The osmosis filter's also just installed for the water filter faucet, not to the sink faucet or elsewhere. So I'd think any water filter makes more sense than a water softener system to address cleaner drinking water, unless we're talking about cleaner/softer water throughout house plumbing to not damage/scale up the pipes with mineral deposits.
Old 01-31-2012, 06:37 PM   #5
Rewards Points: 582
after seeing your picture ..replace faucet,basket strainer,,,and other corroded plumbing.....drinking systems are available everywhere at a reasonable cost...
Old 01-31-2012, 06:50 PM   #6
Rewards Points: 366
On a related note, can't tell if pipes within walls are corroded and worth a repipe w/o tearing up the walls right?
Old 01-31-2012, 06:58 PM   #7
Old steel pipes? Plan on changing them before they leak or close up from rust.
Hard water will corrode the plumbing, make it hard to form suds with soap, load up the bottom of the water heaer ect.
Old 01-31-2012, 07:16 PM   #8
Rewards Points: 582
your on the 1st floor so check out all the plumbing at this point to see what condition its in now would be the time to do it..... yea don't think you need to get into walls...ben
Replace old kitchen sink drain or leave it? CoconutPete Plumbing 23 02-02-2012 01:20 PM
Kitchen sink drain above electrical panel Bahuffma Electrical 8 07-07-2011 09:12 PM
stinky kitchen sink drain 4just1don Plumbing 11 04-14-2010 06:13 PM
Kitchen sink drain replacement Q262995 Plumbing 1 02-24-2010 12:18 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
