Kitchen Sink Drain Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2010, 11:32 AM   #1
Kitchen sink drain replacement
This morning I noticed a leak under my sink. We just recently bought the house, so I haven't had time to explore things like this. I found a hybrid system of brass, copper and PVC. I am in the process of replacing all with new to prevent any new issues from popping up, so I am good on that part.
I am struggling with the removal of the sink drain itself. The ring nut is firmly attached. What tool(s) do I need to be using to get this ring nut off so I can continue on with my installation?
Thanks,
Q262995 is offline   Reply With Quote
Old 02-24-2010, 12:18 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
I normally use slip-joint adjustable pliers, when you slide them all the way open they're the perfect fit to grab around a kitchen drain pipe.
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
drtbk4ever (03-04-2010)
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Sink Drain LaMarguerite Plumbing 2 10-22-2008 04:26 PM
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 05:59 PM
Kitchen Sink Drain powrus Plumbing 4 12-06-2007 05:58 AM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
