-   -   Kitchen sink drain replacement (http://www.diychatroom.com/f7/kitchen-sink-drain-replacement-65156/)
Q262995 02-23-2010 12:32 PM
This morning I noticed a leak under my sink. We just recently bought the house, so I haven't had time to explore things like this. I found a hybrid system of brass, copper and PVC. I am in the process of replacing all with new to prevent any new issues from popping up, so I am good on that part.
I am struggling with the removal of the sink drain itself. The ring nut is firmly attached. What tool(s) do I need to be using to get this ring nut off so I can continue on with my installation?
Thanks,
fetzer85 02-24-2010 01:18 AM
1 Attachment(s)
I normally use slip-joint adjustable pliers, when you slide them all the way open they're the perfect fit to grab around a kitchen drain pipe.
