Kitchen Sink Drain Piping? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2013, 05:21 PM   #1
Rewards Points: 79
Kitchen sink drain piping?
I am having new countertops and sink installed and was wondering if the pros use different drain piping than the polypropylene stuff available at HD? Do you make your own? Or are the pieces available at plumbing supply houses?
Thanks,
Eric
Ebierley is offline   Reply With Quote
Old 04-22-2013, 05:35 PM   #2
Rewards Points: 12,830
What they sell at the box stores will work fine.
Should be able to buy the whole kit in one bag.
Ebierley (04-22-2013)
Old 04-22-2013, 05:39 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 350
Not sure what Poly you're referring to.
Most drain piping is ABS or PVC - readily available at home centers
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (04-22-2013)
Old 04-22-2013, 08:04 PM   #4
DIY staff
Rewards Points: 7,174
One common situation----the new sink drain holes are further back that the old ones---so ,very often, the wall drain piping needs some work----post a picture if things won't line up for you---
Old 04-22-2013, 09:33 PM   #5
Or the sink heigth is differant.
All easy fixes with a tail piece extention.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
leaky kitchen sink drain - simply a case of tightening the joint? pro_DIYer Plumbing 11 07-26-2012 02:36 PM
one drain: toilet, sink, shower and kitchen sink? terreck Plumbing 16 03-18-2011 09:54 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
venting kitchen sink drain illinifan Plumbing 2 05-03-2009 08:26 AM
