Kitchen Sink Drain Leaking Inside Cinderblock Wall. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2016, 12:49 PM   #1
Rewards Points: 119
Kitchen sink drain leaking inside cinderblock wall.
My Kitchen drain is leaking somewhere inside the cinderblock wall, probably where the elbow meets the vent. It was an exterior wall, the porch is now enclosed.
I guess there are two options come from inside the cabinets or the exterior wall.
But what I am wondering is if there is any chance that the builders (1964) anticipated that the pipe could leak and perhaps left some kind of an opening at the elbow where the drain vent meets the drain pipe? Is that at all possible? And what tool is best to use to go through the cinderblock?
SpaceCoast is offline   Reply With Quote
Old 01-15-2016, 01:30 PM   #2
Rewards Points: 289
Hammer as long as the voids in the block are open and not filled with concrete.
ct18 is offline   Reply With Quote
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 12:33 PM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 10:32 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
