Kitchen Sink Drain Correct? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2010, 12:18 PM   #1
DIY Expert in Training!
Kitchen Sink Drain correct?
Needed to get a little creative with my sink drains today. Please take a look at the enclosed picture. If it's dead wrong and needs to be redone please provide me feedback on correct way to do it. If it's good please let me know.
Thanks!
gone_fishing is offline   Reply With Quote
Old 06-20-2010, 12:31 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
id say eliminate the trap coming off the disposal,i dont see a vent anyplace either
plummen is offline   Reply With Quote
Old 06-20-2010, 12:34 PM   #3
I needed the trap to raise the pipe up so I could fit the S trap.
No vent pipe as there wasn't one before. It goes to a main waste pipe that has a vent.
Old 06-20-2010, 12:51 PM   #4
plummen's Avatar
remove the black pipe from disposal and use a straight piece of pipe with flanged end in place of it,then clock the disposal till it lines up with the baffle tee on bottem of sink drain.
youll have to raise the baffled tee and the trap on your s-trap to make it work
Old 06-20-2010, 01:20 PM   #5
Owner
LateralConcepts's Avatar
Looks like a leak(s) waiting to happen. Shouldn't need so many fittings, nuts, etc. 1 trap, 1 continuous waste, 2 flanged tailpieces, long sweep 90, and trap adapter.
LateralConcepts is offline   Reply With Quote
Old 06-20-2010, 03:07 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
A picture is worth 1000 words.
http://www.nettally.com/palmk/GDplumbing.html
Just for clarification, the picture at the top is what you want it to do, not the hodge podge of mish-mash he has at the bottom. That bottom picture is wrong.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (06-20-2010)
Old 06-20-2010, 04:18 PM   #7
Better?
I turned on the water for the first time since May 8th. Popped a minor leak on the water filter. Tightened and all clear...knock on wood.
Old 06-20-2010, 07:09 PM   #8
plummen's Avatar
go with the first picture in alans post,its basically what you need other than running an s-trap versus a p-trap
Old 06-21-2010, 09:13 AM   #9
Doing it myself
Alan's Avatar
Originally Posted by gone_fishing View Post
Better?
Better, and it will work, but if you notice the picture I linked to, the tee is directly below the side of the sink opposite the disposer. It's called a disposer tee if you decide to go buy one someday, you can eliminate a couple of joints there.
Journeyman Plumber
Old 06-21-2010, 10:10 AM   #10
Chicago, IL
Michael Thomas's Avatar
In many places I inspect separate traps are preferred or required, but if someone is going to go to the trouble to retrofit them as illustrated, a double wye providing a clean out would also be required.
Iím paid to be suspicious...
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 06-21-2010, 09:41 PM   #11
Doing it myself
Alan's Avatar
By our code, we would then be required to add a 2nd drain and vent. One trap arm per vent, one trap per trap arm.
Journeyman Plumber
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
