Old 09-21-2008, 02:59 PM   #1
Kitchen Sink Drain - brown buildup?
I have dual sinks in my kitchen - one of them is perfectly normal and shiny.
The other one is the problem. The drain is BROWN and it looks cracked. It's quite nasty - you can scrape it with a spoon but nothing happens when you wipe it with a cloth....
Any ideas? My camera cord is missing so I can't show you the pictures...
Krista is offline   Reply With Quote
Old 09-21-2008, 03:18 PM   #2
Moderator
Termite's Avatar
What is the sink made of? Does it look cracked, or is it actually cracked?
Old 09-21-2008, 03:20 PM   #3
The sink is stainless steel. It looks like the buildup is just on the strainer basket and it's cracked....I can't really tell what's going on. I'm going to see if I can hook up my camera and show the pictures.
Old 09-21-2008, 03:27 PM   #4
Here we are:
Old 09-21-2008, 05:38 PM   #5
Moderator
Termite's Avatar
The cracking is probably the laquer finish that used to give it its shine.
Try soaking the sink with a product called CLR (calcuim-lime-rust). That should remove the gooky buildup.
Old 09-21-2008, 06:27 PM   #6
Thanks a lot - I'll try that. If that doesn't work I will have to see about replacing it.
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 06:59 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Kitchen Sink Drain powrus Plumbing 4 12-06-2007 06:58 AM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
