Kitchen Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2010, 01:57 PM   #1
kitchen sink drain
Have an older home with a cast iron stack and I believe a lead pipe coming out (probably 1 1/2"), running along the wall and out under the kitchen sink to connect to the trap. We are moving the sink and need to extend that line running along the wall. Can we just cut off the curved end of the pipe and connect pvc to it with a fernco type connector to extend the drain line to the new location? Any code problems with this?
joehag is offline   Reply With Quote
Old 09-15-2010, 03:46 PM   #2
Owner
LateralConcepts's Avatar
Not to code. Eliminate all of the lead. You'll need to re-plumb it all the way back to the stack. A kitchen drain should also be 2".
and if you cast your own bullets...
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 09-15-2010, 07:21 PM   #3
The lead is code, but the only approved way I know of to add to it is a wiped joint. Not too many plumbers work lead anymore, so chances of finding someone to do it is slim. Do as LC said, cut it to the cast iron stub, and run a new line to your new sink. Make sure it's 2" pipe, and properly vented as well
the_man is offline   Reply With Quote
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
kitchen sink drain hole lucylu092910 Plumbing 1 04-19-2010 08:59 AM
Kitchen Drain Dilemma DIYaholic Plumbing 4 01-13-2010 08:23 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
