Old 11-29-2012, 03:13 PM   #1
Kitchen Sink Drain
I am having a few plumbers come by my place to quote on what it would cost and how they would plan on running a new section of plumbing. However I am not well versed in the world of plumbing so I'd like to know a little before they stop by.
I have a kitchen sink that has been moved and it needs to run to the main stack. Here is a drawing showing the existing floor joists, the existing drain and where the new drain is. What would be your plan of attack to run a new drain?
I am guessing it would use 1-1/2" pipe and it would run 48" to the right and then a 90 degree elbow to have it run to where the old drain started? Could you even do a 90 degree elbow on a drain? Or cut through the joists to have it run directly from the new drain to where the old one is?
I won't ask what would a plumber charge, as I'm sure the rates vary.
marcopolio is offline   Reply With Quote
Old 11-30-2012, 01:30 PM   #2
Special User
Kitchen Sink Drain
The drain needs to be vented near the sink. A quick search suggests a 1.5" drain needs a vent within 10 times the diameter of the pipe, so, within 15" of the P-trap.
Even with a 3" pipe you only get to run 30" before venting, so I don't think that 48" + 90" run isn't going to fly without adding a vent.
Assuming you can add a vent at the new sink location, I don't think the 90° bend is a problem if a sweep ell is used and there is adequate pitch everywhere. However you'd better ask a real plumber to be sure.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 11-30-2012, 03:20 PM   #3
Kitchen Sink Drain
Yep no worries about the vent, there is a 1.5" dia vent going through the wall which will be connected after the p-trap in the cabinet via a sanitary T.
Old 11-30-2012, 08:02 PM   #4
call me E
TheEplumber's Avatar
Kitchen Sink Drain
FYI- Your quick search was not thorough enough. UPC allows 42" trap arm for 1.5" and 6' for 3"
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Alan (11-30-2012), ben's plumbing (11-30-2012)
Old 12-03-2012, 10:03 AM   #5
Kitchen Sink Drain
Thanks for the advice. Plumber is routing it the 48" to the right, with 1/4" slope per ft. When it changes and goes down, he'll be using two 45 degree bends. From there it will have 1/4" slope per ft all the way to the main stack.
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 03:37 PM
Leaking drain pipe under kitchen sink dethun Plumbing 20 09-26-2012 08:30 AM
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 09:45 PM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Help: Kitchen sink drain is clogged with grease cips Plumbing 4 08-10-2009 11:11 AM
