Kitchen Sink Disposal Drain Trap Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 10:40 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 556
Originally Posted by mystic_cobra View Post
I understand your description of how to lower the drain pipe that goes out the wall and I appreciate your assistance.
I'm asking if I can insert some piece of pipe between my metal trap and that 90 deg bend (where the white thread tape is in this picture below) that would lower the trap so I could make the connection without cutting into the wall?
As for posting pics on forums, I upload them to imageshack (free pic hosting) and then link to it from the forum post.
Good luck finding something to do that. That has a ground joint mating surface where the tape is. If thats the method you choose to fix it, just turn the J piece 180 degrees and add an extension at the disposal. But by doing this, your trap is now extra deep so it will be more pron to plug
Old 02-05-2012, 01:19 AM   #17
DIYer
Rewards Points: 262
Originally Posted by plummen View Post
Can you post a better picture?
The first picture in my first post is probably the best. It shows the waste pipe headed out to the wall and the disposal exhaust at nearly the same level.
The final picture shows the J-trap pipe connected to the waste pipe.
Is there something specific I can take a pic of that will help?
mystic_cobra is offline   Reply With Quote
Old 02-05-2012, 08:47 AM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
a wider angle shot would help
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-06-2012, 09:19 AM   #19
DIYer
Rewards Points: 262
Tough to get a wide angle shot from under the sink. Here's a couple more...
From the right side of the disposal...You can see the original metal pipe with the 90. I think the 90 is zinc coated or something bc it is original and looks unusually good for its age. Is this copper or some other metal?
From the front left side
So, a buddy came by yesterday who does house renovations. He suggested I unscrew the 90 and get an adapter to transition to PVC. Then get a standard trap kit for a sink and it will have all the pieces I needed to drop the trap down so that I can connect to the disposal exhaust without cutting up any walls. Does that sounds realistic?
Old 02-09-2012, 07:47 AM   #20
DIYer
Rewards Points: 262
I located a fernco fitting that has a rubber molded sleeve on the inside sized for copper on one end and pvc on the other. It has a metal sleeve that goes around it with two radiator-style clamps. Looks like a nice piece.
If I can find the right collection of pvc pipes, which shouldn't be too tough, I should be able to hook this up.
The plumbing supply had a pvc trap that was larger pipe than what I've seen at HD, Lowes. He said it's the same 1.5" at the connections, but it looks like the pipe you put inside walls vs what I usually see under a sink. Other than the obvious physical difference, what's the difference? Can both be used interchangeably?
Does the code specify a minimum distance that the water must drop from the disposal to the drain pipe?
Should have done this a while ago but I've got a buddy bringing me a DIY plumbing book.
Old 04-13-2012, 09:13 PM   #21
DIYer
Rewards Points: 262
Question
Question about trap seal height and drop
A couple of procedural questions...
Does the code specify a minimum distance that the water must drop from the disposal to the bottom of the trap?
Also, is there a minimum or maximum distance (height) for a kitchen sink trap?
Found this image googling that suggests it should be between 1.5" and 4". Can any plumbers confirm this?
http://www.showroom411.com/Media/CMS/2010/1643_R.jpg
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
kitchen sink drain joehag Plumbing 2 09-15-2010 07:21 PM
kitchen sink drain annalula Plumbing 3 03-30-2009 02:39 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 05:59 PM
