Old 02-04-2012, 05:18 PM   #1
Question
kitchen sink disposal drain trap problem
I am installing a new disposal under a new sink to an old waste drain. The drain is metal. It looks like cast iron, but might just be thick copper. House was built in 1965.
The new single sink is deeper so the disposal sits lower. I have the correct connections via the trap and disposal exhaust but my pipes don't line up. The exhaust from the disposal is nearly at the same level as the drain pipe. Once I connect the trap to the waste pipe, the top of the trap is now too high for the exhaust from the disposal.
The kid at home depot says you cannot extend the down stream side of the trap which would lower the trap but allow the exhaust from the disposal to connect easily. Instead he suggested a pair of form-a-fit tailpieces to make the connections. I think this is a jack job but I think it will make the connections.
How should I handle this? Is this a common issue?
mystic_cobra is offline   Reply With Quote
Old 02-04-2012, 05:37 PM   #2
mock up of connections without straight exhaust pipe from disposal.
Old 02-04-2012, 05:41 PM   #3
please don't even think of doing it that way...
Old 02-04-2012, 06:11 PM   #4
Yeah, I know that's ridiculous. I might do it until I can get to a real plumbing supply store on Monday as we need the sink this weekend.
I'd like to extend the wall drain pipe down and just lower my trap if an extension pipe exists and its legal for code. This seems the cleanest.
Old 02-04-2012, 06:14 PM   #5
ok you made me fell much better you know what your doing about lowering the drain to do it right....yea if you need sink go for it let us know how it works.....
Old 02-04-2012, 07:39 PM   #6
So, can I connect a pipe (or series of pipes) to fix this and have it pass code without opening the wall to lower the drain pipe?
Old 02-04-2012, 07:44 PM   #7
no you have to cut wall to lower piping to accept drain ...you can't elbow existing drain down...if thats what your thinking..sorry... keep in mind there should be a vent there as well
Old 02-04-2012, 07:51 PM   #8
I'm assuming the vent is at the top of the waste pipe. The sink was here previously. I'm not sure why you mention that.
This sucks.
Old 02-04-2012, 08:00 PM   #9
This sucks.
you have to cut wall open ..cut copper drain intall tee or wye which ever will fit best... i like wye use fernco couplings set drain to accept drain from disposal... I mention vent because if you were to just elbow down drain comming out of wall and installing disposal drain with trap you would be double trapping ...which would affect vent
Old 02-04-2012, 08:36 PM   #10
Ah, now it makes sense.
Double tap = good.
Double TRAP = bad.
Just so I'm clear... Does a short pipe that would hypothetically go between my drain-to-wall pipe and my trap which would lower my trap not exist or is it not legal for code?
Old 02-04-2012, 08:42 PM   #11
Double tap = good.
Double TRAP = bad.
not sure I understand you..but again.. if you open wall cut off pipe that is existing connect to vent instaLL TEE OR WYE to new height connect to existing lower drain line...hope you understand this... ps I dont know how to post a picture..HA HA that is sad...
Old 02-04-2012, 08:54 PM   #12
I understand your description of how to lower the drain pipe that goes out the wall and I appreciate your assistance.
I'm asking if I can insert some piece of pipe between my metal trap and that 90 deg bend (where the white thread tape is in this picture below) that would lower the trap so I could make the connection without cutting into the wall?
As for posting pics on forums, I upload them to imageshack (free pic hosting) and then link to it from the forum post.
The Following User Says Thank You to mystic_cobra For This Useful Post:
ben's plumbing (02-04-2012)
Old 02-04-2012, 08:59 PM   #13
Ok think i understand..you could try it it is very close to flow line...so you want to lower the j bend to pick up disposal making the trap longer...never did it ...try it.. could work.... let me know...
Old 02-04-2012, 10:44 PM   #14
Ok, cool. I think we're on the same page now.
So, J-trap, P-trap... all the same?
Old 02-04-2012, 11:37 PM   #15
retired elect/hvac/plumb
plummen's Avatar
Can you post a better picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
kitchen sink drain joehag Plumbing 2 09-15-2010 08:21 PM
kitchen sink drain annalula Plumbing 3 03-30-2009 03:39 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 06:59 PM
