Kitchen Sink/Counter Cutting Help? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2006, 12:31 AM   #1
Kitchen Sink/Counter cutting help?
Hello all,
I am new here and you all seem to be very knowledgeable. I have an issue with installing a steel sink in a formica countertop. My contractor friend was helping me, and when we traced the sink outline, the place for the sink clips in the front is blocked by a crossbeam in the cabinet directly below. Because of this, my friend said that the clips cannot be installed and tightened and the countertop will not be watertight. I tried finding a shorter sink, but 22" seems to be standard. Does anyone have any ideas on how to make this sink work? I thought of maybe cutting small square sections out of the crossbeam to make room for the clips. Would that work? I am inexperienced but willing to try almost anything. Thanks in advance for any help.
This is the part of the outline with the beam directly underneath
This shows the beam and the outline above.
Lambo is offline   Reply With Quote
Old 06-07-2006, 06:54 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Run a bead of silicone caulk all around under the sink lip to seal it.
Works for me.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-07-2006, 07:17 AM   #3
It looks like you are mounting the clips on the front of the sink. Is it possible to locate the clips on the sides close to the front of the sink?
Before you put the sink into position put a bead of caulk around the sink rim. Put the sink in place, tighten the clips, put the drain stopper in and then fill the sink with water to put downward pressure on the caulk. Fill the sink as high as possible with water. Let the water stay in the sink until the caulk dries.
redline is offline   Reply With Quote
Old 06-07-2006, 10:32 AM   #4
renovations
Yeah, you're stuck with the advice you've already gotten. I'd also add one reminder: When you have cut the sink hole out, SEAL THE EDGE with caulk, just rub it in with your finger, this way if you get a drip or two of water under the sink it won't instantly destroy your countertop.
Bonus is offline   Reply With Quote
Old 06-07-2006, 12:29 PM   #5
Hey, thanks a lot guys, I feel a lot better about trying this now. Bonus, do you mean to apply caulk separately to the exposed part of the pressboard on the inside of the cut, before putting the sink down(which will be caulked separately) to do that sealing you discussed? Thanks again all.
Old 06-08-2006, 12:04 AM   #6
renovations
Yes, exactly, you're trying to ensure that the open edge of the mdf is protected from water. I like to spread caulk out for a ways underneath the counter too, away from the cut edge.
It's a cheap thrill, and you'll never have better access than right now until you have to replace the counter which you won't have to do if you do it. (That's a mouthful)
Old 06-08-2006, 12:07 AM   #7
renovations
Maybe you've done this project already, but they do make kitchen sinks at 18" front to back. I'm working on a place right now that has one.
Old 06-08-2006, 08:31 AM   #8
If you seal the cut edge under th sink then that reduces the possiblity that water will soak into the particle board and seperate.
You could use oil base poly, oil base primer... not latex.
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
Kitchen sink/counter cutting help? Lambo Carpentry 4 06-17-2006 05:50 AM
Kitchen remodel frank551 Electrical 2 11-15-2005 08:13 PM
