Kitchen Sink Centered On Cabinet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2010, 05:46 PM   #1
Kitchen sink centered on cabinet?
I'm installing a new kitchen sink on a 36" sink cabinet at the far left end of a countertop. I'd like to leave some countertop to the left of the sink, which would require off-setting the sink to the right on the sink cabinet. I've seen a couple websites that insist the sink should be centered on the cabinet, however. I can't think of any reason that this should be so. Any opinions? Thanks!
--Chris
sillyboy22 is offline   Reply With Quote
Old 03-02-2010, 06:56 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
Chris,
In most cases, especially if the sink it symetrical, I try to center the sink on the sink base. Usually there is a window above the sink. I try to center the sink and sink base on the window centerline. Purely for aesthetics. How far were you thinking about moving the sink off center? If you are using a sink that has one large bowl and one small one, sometimes being off center isn't as noticeable.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-02-2010, 09:06 PM   #3
Rewards Points: 1,016
I had to decide whether to center sink and base on a window, or offset about 6" to allow room to get a lazy-susan into the corner. I thought centered, my wife said offset was ok. We offset it - and she was right. We nor nobody else notices. I doubt if your situation would be noticeable or a problem either.
Old 03-02-2010, 09:16 PM   #4
Good enough for me. Thanks!
--Chris
PVC vs FMC vs AC vs ENT for cabinet under kitchen sink? tigereye Electrical 1 02-21-2010 08:28 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
