Kitchen Sink Backs Up On Both Sides. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2011, 12:27 PM   #1
Kitchen sink backs up on both sides.
I plunged the side without the disposal and both sides of water went down but when you try to run water, it immediately backs up again. I checked the p trap and it was clear. I then bought a hand crank snake and it reaches a certain point and will go no further (did this on both the disposal side and the other side). Tried serveral times to push past the blockage but it wouldn't go. Before I call a plumber, is there anything else anyone can suggest. (the house is on a slab so no basement access)
nanlau is offline   Reply With Quote
Old 08-25-2011, 02:39 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A plumber's snake will usually only plunge right through the grease and other organic kitchen gunk blockage.
Before calling a plumber, do what I do....use a good enzyme-based drain cleaner like DrainCare. You run warm water down the drains, pour in the DrainCare and let it eat the organic gunk out overnight, and then flush it all down with hot water. I always start the flushing the next morning with a kettle of boiling water. If the clog is really bad, you may have to do it more than once, but it always works.
Enzyme-based drain cleaners, unlike caustic drain cleaners, will not harm your fixtures or pipes or you.
Works for me!
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-25-2011, 05:48 PM   #3
Sorry to disagree - do not put any drain cleaner down there at this time. If you can't unclog it that way you are now dealing with a hazardous chemical as well as a clog.
If no other drains backing up now - it looks like it is just the fixture drain so it shouldn't be too far down.
I would try a few more times and then rent a drain cleaning machine.
castiron is offline   Reply With Quote
Moving kitchen sink teachtech Plumbing 4 08-08-2010 10:13 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Help moving kitchen sink pflaxman Plumbing 2 09-22-2009 12:19 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
