Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2010, 03:36 PM   #1
Kitchen sink
The more water i pour into sink, the more more slower it will drain. Something it blocking in one of the pipes. I had this problem a year ago.I removed the pvc pipe in kitchen to see if anything was blocked, but there was nothing. So it is probably the pipes behind the wall. Is there a way to fix this?
StevenH is offline   Reply With Quote
Old 04-25-2010, 12:17 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
call the drain guy
plummen is offline   Reply With Quote
Old 04-25-2010, 12:39 AM   #3
Originally Posted by plummen View Post
call the drain guy
If i go buy a Kwik-spin, would that work?
Old 04-25-2010, 09:58 AM   #4
I'd try a plunger, just not the same one already used on the toilet. The quick spin might work, but it shouldn't be a long run to the main drain pipe, in which case a 1/4" cable won't be effective with the clog. If you are able to see the drain pipes from the basement, you can look for a clean-out on the main. And if you have a dishwasher connected to the sink, it might hinder the effectiveness of the plunger.. If all else fails, there is always chemicals, which I only like to use as a last resort.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 12:01 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
