Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2008, 04:18 PM   #1
kitchen sink
my kitchen sink was leaking very badly at a threaded joint so i took it apart and after seeing how clogged everything was decided to put in new from the drain to the trap. the old stuff said inch and half but when i went and bought inch and a half and brought it home it is much larger than the original. are the diameter measured differently and did i buy the right type of pvc just the wrong size? help i have no kitchen sink
samiller1980 is offline   Reply With Quote
Old 11-25-2008, 05:17 PM   #2
I'm assuming you wanted to use the pipe that connects with a slip joint, and you got the pipe that is glued to connect.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-25-2008, 05:41 PM   #3
yes i discovered my problem, i was using regular pvc and not the stuff that is desinged for sinks and such, it is fixed.
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
How difficult to remove a kitchen sink? Ultrarunner2017 Plumbing 6 11-14-2008 03:28 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
