Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2015, 10:28 AM   #1
Rewards Points: 2
Kitchen sink
Okay, I have had it with my kitchen sink. I thought it was clogged so I took off all the pipes and they were all clear. I then decided to do some methods for unclogging drains in the pipe going directly down in my floor. Now all the water went right down, so I assumed my method worked. No. I hooked all the pipes back up and BAM it is clogged. so I go to remove my pipes again and I notice the water is stopping in the elbow or Pea trap. However there is no blockage in there. So why is my water staying there and the flowing through the pipes? Any suggestions from anybody on what this could be.
peanutsgirl is offline   Reply With Quote
Old 01-09-2015, 11:40 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Post up a picture of the sink plumbing.
Is this a brand new problem?
Old 01-09-2015, 02:56 PM   #3
Rewards Points: 348
Water should always stay in the p-trap or s-trap which ever you have. That is what keeps sewer gas from getting into your living space. Sewer gas not only stinks it is also potentially a health hazard and explosive hazard.
Your post says "I thought it was clogged". In my experience, there is usually no question it is clogged because the sink drains slowly or not at all. I am wondering if you are seeing water in the trap and assuming it should be empty???
RegeSullivan is offline   Reply With Quote
The Following 2 Users Say Thank You to RegeSullivan For This Useful Post:
r0ckstarr (01-09-2015), ToolSeeker (01-09-2015)
Slow drainage and gurgling, overflow in kitchen sink daluu Plumbing 10 04-06-2014 10:29 PM
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
