Old 11-10-2012, 10:12 PM   #1
Kitchen sink
How do I remove a kitchen sink without breaking the tile underneath the edges
Dave eriksen is offline   Reply With Quote
Old 11-10-2012, 11:32 PM   #2
Kitchen sink
If it's a drop in sink with a rim (ie the hole in countertop is smaller than outer dimension of the sink), first disconnect plumbing. Drain and supply lines.
Use a utility knife with a long sharp blade to slide under edge. Work all the way around on at least 3 sides. Wall side may be impossible. Typically sealed with silicone. Then maybe a putty knife to get a little further in. A partner should try to push up from inside cabinet until seal is broken. Should be pushed up and then lifted up evenly on all sides to avoid damage to surrounding tile by tilting.
diyorpay is offline   Reply With Quote
Moving kitchen sink teachtech Plumbing 4 08-08-2010 11:13 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 04:17 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 08:37 PM
