Kitchen Revamped, Help With Sink Drain Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2011, 07:57 PM   #1
kitchen revamped, help with sink drain plumbing
Hello. Hope someone can provide an easy solution. Kitchen sink was moved to corner and now sits almost 8 feet from the original stack. Stack is only 1.5 inch cast iron which actually feeds kitchen as well as the utility sink in basement which has washer drain into it also the sink in the down stairs bathroom.
This seems like a bit much for a 1.5 inch pipe but I guess that's just how they rolled in the 50s?
Anyway I do not plan on ripping the house apart including ripping up the basement floor but what are my options for moving this sink over? I believe code says 5ft for 1.5 inch pipe before it needs another vent. I would really rather not use a aav if possible. Going to try and attach pic, doing this with phone so bare with me....
In pic you can see where old drain was, new drain will have to go in that far corner
kitchen revamped, help with sink drain plumbing-forumrunner_20110929_205458.jpg
rfire15 is offline   Reply With Quote
Old 09-29-2011, 08:03 PM   #2
DIY staff
Rewards Points: 7,174
Let me guess---the cabinets are already installed?
Kinda put the cart before the horse----
Post a picture of the upstairs and is this a single story or 2 story house.
Old 09-29-2011, 08:09 PM   #3
No cabinets are not installed, finishers should have the room paint rdy by tomorrow.
I could maybe re pipe that vent a bit, do a T off it and connect the vent farther up that pipe... And even run 2inch drain to that part if it might help.... Nothing I can do ultimately about that overall drain being 1.5 inch though
Old 09-29-2011, 08:11 PM   #4
Sorry, 2 story but on that side of the house it is attic space on 2nd floor... Cape cod
Old 09-29-2011, 08:19 PM   #5
DIY staff
1 1/2 inch will be fine for a kitchen drain---2 is better but 1 1/2 will work--
You should have gotten the vent into that wall before you finished the drywall---now you are stuck with an AAV or a lot of drilling to get the vent above the drain line and back to the old vent.
If it were my job ,I'd cut the old pipe 9" above the basement floor--repipe the slop sink and lower the kitchen drain away from the ceiling --allowing the vent return pipe to hug the floor joists.
A wide angle shot of the pipe to the floor and up to the ceiling would help---
Old 09-29-2011, 08:33 PM   #6
I could do that, T off the slop sink and run drain closer to floor then up the corner to the kitchen.
Is it ok to loop the drain vent up inside the sink base (using a T under the sink) then back down into the basement... Then can run the pvc along the floor joists back to the vent. Will just redo the whole stack with pvc and connect it to the old cast iron at the bottom and top... I guess that's what u ment?
Old 09-29-2011, 08:45 PM   #7
DIY staff
No on the loop--you will create a giant P-trap that will fill with condensation and stop working.
Run drain pipe below window---vent above the window--pitched to the drain--attach vent to old existing pipe.
Sorry I'm not long on words tonight---I'm tired.---Mike---
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Kitchen, sink, plumbing ?'s Canada 83trekker Plumbing 3 01-10-2010 01:31 PM
Kitchen remodel, sink drain rework pinkertonpv Plumbing 3 02-18-2009 10:06 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
PLEASE HELP..Kitchen Sink Plumbing!! davo420 Plumbing 6 02-28-2006 06:37 AM
