Kitchen Remodel, Strange Plumbing. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 11:29 PM   #1
shbhalla's Avatar
Kitchen remodel, Strange plumbing.
I gut my kitchen today and was kind of surprised to see the kind of plumbing done. With the way it is not, I cannot put a new cabinet in at all unless I cut a large hole in the bottom of the cabinet. I am attaching a picture.
Looking at it, What are my options? Do I cut the waste pvc pipe about 5-6 inches from the floor and do the plumbing after the cabinet is in?
I kind of find the water pipes strange as well. I will have to remove that too in order to create the smallest hole possible in the cabinet. Any Ideas how I can take care of both these issues without causing much damage and also avoid major plumbing work.
shbhalla is offline   Reply With Quote
Old 07-28-2012, 11:36 PM   #2
Rewards Points: 13,296
If it was my job to do I'd remove the drywall and rerun the drain so it was behind the wall not through the floor the way it was suppost to be run.
That looks tubing that was run wrong in my opion also. It was suppost to connected behind the wall to copper subouts. That way all you saw on the wall side was two copper tubes sticking out.
shbhalla (07-29-2012)
Old 07-29-2012, 01:18 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
Cut the waste pipe off above the cabinet base as you suggest. Then you can rebuild it to match your new sink. For the waters I'd cut a square out of the cabinet back to receive the water supplies. Done properly, it will look like it was meant to be. Pex is stubbed out quite often now days and cabinets sink cabinets are often sold without backs too. They work great for these situations
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-29-2012, 05:05 PM   #4
shbhalla's Avatar
Thanks that seems to be the best option as well.
Old 07-29-2012, 07:41 PM   #5
Rewards Points: 162
I'll second the recommendation to open up the wall. Is there some reason they couldn't get the drain pipe in the wall and run a standard vent up and out of the roof. Judging from the plywood floor, I'm gonna guess you have a basement or crawlspace under this area - take a look and see if the pipe can be moved back without interference.
The AAV should be a last resort - it also belongs 6" above the flood rim of the fixture which doesn't seem possible in this scenario.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-29-2012, 08:29 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
As noted above....two options.....
1. Open up the wall and put the drain in there.
2. Cut it off at the floor then rebuild.
The final choice depends on how OCD you are....and how easy the access is from below.....downside to option 1...beside having to plug a hole in the floor.
With that said...this is a good example of why we have building codes.....and inspections...and permits....
Not trying to make you feel bad....but...It makes me wonder what the rest of the house looks like under the wrap.
ddawg16 is online now   Reply With Quote
Old 07-29-2012, 08:58 PM   #7
shbhalla's Avatar
So there is a basement in this house. I will check the basement and report back. Fortunately it is unfinished. The bathroom on this same floor has exactly the same plumbing. I think this was a standard The builder (Pulte) had back in 2000.
Old 07-30-2012, 02:35 AM   #8
I'd go with the others and suggest that now is a good time to get the drain in the wall.
Was the original a 2 bowl sink with 2 traps on it? Or was there a dishwasher?
Also looks like the hot water has 2 valves. Was there also a dishwasher there that's going back.
Evstarr is offline   Reply With Quote
Old 07-30-2012, 08:22 AM   #9
shbhalla's Avatar
Yes 2 sinks and a dish washer to the left of the sink had attachments from here.
Shelley.
Kitchen remodel leiona Project Showcase 251 10-04-2012 10:58 AM
Kitchen remodel and venting joeh Plumbing 5 12-17-2011 07:38 PM
Plumbing Kitchen Sink on Outside wall in Cold Weather Climate (MN) tpthaler Plumbing 4 04-15-2010 08:36 AM
Outlet & Lighting in kitchen remodel vjbozard Electrical 4 04-08-2009 03:17 PM
Conquering a Kitchen Remodel skip97 Remodeling 2 02-27-2008 08:54 PM
