Old 11-23-2012, 09:52 PM   #1
Kitchen plumbing line up
In redoing kitchen I noticed my current kitchen drain is not in center of sink cabinet. It looks to be about 6 inches off from center. Can i still install the drain without an issue? I may have to run the pipe lateral a few inches. Can this be done without an issue?
skinut2234 is offline   Reply With Quote
Old 11-23-2012, 10:02 PM   #2
Got a picture?
As long as it runs down hill it should be fine.
Old 11-23-2012, 10:17 PM   #3
Super Moderator
Yep--as long as the drain is inside the base cabinet you will be able to make that work---
Old 11-23-2012, 10:24 PM   #4
May want to try 2, 45's.
Old 11-23-2012, 11:00 PM   #5
on a standard double bowl kitchen sink the drain holes are 8 inches off center. but like oh"mike said as long as it's in the cabinet it will work
Old 11-24-2012, 09:34 AM   #6
I had same issue when going from an old double bowl sink to a new single bowl. remedt was to use a 1.5" 45 fitting on the stub out from the wall then a short piece of 1.5 then the trap adaptor
Kitchen plumbing line up-100_5712.jpg   Kitchen plumbing line up-1124120916.jpg
hammerlane is offline   Reply With Quote
Old 11-24-2012, 09:41 AM   #7
Home Remodeler
This is at least a two trip to the hardware store. LOL
mikey48 is offline   Reply With Quote
Old 11-24-2012, 11:03 AM   #8
What is the "this" that you refer to?
plumbing supply line mitramarket Plumbing 4 08-27-2011 03:35 PM
Plumbing a washer/dryer combo into kitchen sink VersaBar Plumbing 10 12-01-2010 09:17 PM
rerouteing drain line from kitchen errolnavickas Plumbing 2 10-25-2010 07:56 PM
main plumbing line runs through another persons yard! ams4349 Plumbing 4 10-19-2010 12:46 AM
PEX plumbing inspection and vent line ideas jeste Plumbing 2 02-10-2010 06:35 AM
