-   -   Kitchen plumbing line up (http://www.diychatroom.com/f7/kitchen-plumbing-line-up-164489/)
skinut2234 11-23-2012 09:52 PM
In redoing kitchen I noticed my current kitchen drain is not in center of sink cabinet. It looks to be about 6 inches off from center. Can i still install the drain without an issue? I may have to run the pipe lateral a few inches. Can this be done without an issue?
joecaption 11-23-2012 10:02 PM
Got a picture?
As long as it runs down hill it should be fine.
oh'mike 11-23-2012 10:17 PM
Yep--as long as the drain is inside the base cabinet you will be able to make that work---
joecaption 11-23-2012 10:24 PM
May want to try 2, 45's.
DannyT 11-23-2012 11:00 PM
on a standard double bowl kitchen sink the drain holes are 8 inches off center. but like oh"mike said as long as it's in the cabinet it will work
hammerlane 11-24-2012 09:34 AM
2 Attachment(s)
I had same issue when going from an old double bowl sink to a new single bowl. remedt was to use a 1.5" 45 fitting on the stub out from the wall then a short piece of 1.5 then the trap adaptor
mikey48 11-24-2012 09:41 AM
This is at least a two trip to the hardware store. LOL
hammerlane 11-24-2012 11:03 AM
What is the "this" that you refer to?
