Kitchen Faucet Sprayer Barely Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2012, 12:48 PM   #1
Kitchen faucet sprayer barely working
I had a new kitchen faucet and sprayer installed a while ago. The new sprayer has never worked properly. The sprayer just dribbles. I re-checked the diffuser and it is clean as a whistle. Bought another sprayer head, still the same problem. The original faucet and sprayer worked fine so why won't this sprayer work? Hate to call a plumber because of $$$. Please help.
tamster341 is offline   Reply With Quote
Old 05-23-2012, 01:43 PM   #2
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Does water keep coming out of the faucet when you push the sprayer handle?
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 05-23-2012, 04:27 PM   #3
Michelle,
No, the water does stop coming out of the faucet when I engage the sprayer.
Old 05-23-2012, 08:51 PM   #4
Rewards Points: 6,652
Can you post a picture of the sink with the faucet & sprayer please, or manufacturer & model#. If you are able to press the trigger, and the water stops flowing at the faucet, that means the head is screwed up. If this is just a sprayer coming up through the sink on the back, and not a faucet that the sprayer is also the faucet, you can get replacements at Lowe's, Home Depot, Ace Hardware, etc.
Old 05-23-2012, 08:56 PM   #5
DIY staff
Rewards Points: 7,174
Some sprayers have a tiny back flow preventer in the line--usually where the faucet and spray hose meet--a small bit of crud will stop up that valve--
Old 05-23-2012, 10:40 PM   #6
Rewards Points: 582
some faucets have a pop it valve in spout that open and closes with the squease of the sprayer button....have to remove spout cap to check it ....picture would help...
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 02:00 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 08:55 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 04:27 PM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 01:08 PM
Faucet not working.... adking1973 Plumbing 2 10-09-2008 07:46 PM
