Kitchen Faucet Noises - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2010, 12:00 PM   #1
Kitchen faucet noises
Hey,
My kitchen faucet has been making a weird noise since we moved in. It goes away for a few seconds when I use the little spray nozzle but then comes right back.
Does the same thing with hot and cold. Any quick advice?
tertius is offline   Reply With Quote
Old 01-21-2010, 08:41 PM   #2
Fawcet Noise
I had the same problem with a Price Pfister fawcet. I wanted to change it
and install a new one. But, the problem was with the washers. I replaced
the washers and seats and the rings around the bonnet and it di not make
any more noise. I am not sure about other brands of fawcets.
Gabriel24 is offline   Reply With Quote
Old 01-21-2010, 09:43 PM   #3
Do something
D'Brie's Avatar
Originally Posted by tertius View Post
Hey,
Make sure your stops (little valves under your sink) are fully turned open.
D'Brie is offline   Reply With Quote
Old 01-21-2010, 11:19 PM   #4
The stops are fully open and I don't think it's a washer problem. The attached spray nozzle gets the feed before the washer in the main faucet would get it. That stumped me (of little knowledge).
Old 01-22-2010, 01:48 AM   #5
Do something
D'Brie's Avatar
Is there anything lodged in the aerator (where the water comes out of the spray head and faucet)? Is this happening at other fixtures in your home; possible high water pressure (greater than 80psi). is the faucet worth reparing, is it old and should be replaced? Just a process of elimination here.
Old 01-25-2010, 12:41 AM   #6
The sound isn't coming from the aerator and they are clean. When I open it up just a little bit I can't hear the sound though... And no, just in the kitchen.
Any other tips?
Old 01-28-2010, 09:15 PM   #7
As far as I can tell the sound is coming from the bottom of the faucet. Not the pipes in the wall.
Should I try to open the unit up and look for blockages?
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 10:44 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 09:28 AM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 04:16 AM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
