Old 08-24-2007, 09:23 PM   #1
Kitchen Faucet makes a CLUNKING sound!!
My single handle delta kitchen faucet makes a clunk (sometimes a few clunks) when water is turned on. I have replaced the 2 springs and rubber seats. The "clunking" is intermittent. It happens with both the hot and cold water. No other faucets in the house make the "clunking" sound!
I need the cause and the solution please!!!!
Thanks, Nancy
jcdonkey is offline   Reply With Quote
Old 08-24-2007, 11:02 PM   #2
Custom Cabinet Maker
Sounds like the spray diverter. Unscrew the aerator, diverter should be under it, clean everything and then see what it does.
JackM
skymaster is offline   Reply With Quote
Old 08-24-2007, 11:43 PM   #3
Thank You, I will certainly try this, however the faucet is doing it when I use the main handle to turn on the hot and cold water. But I will give it a try anyway.
Thanks,
Nancy
Old 08-25-2007, 12:16 PM   #4
Nancy, the diverter is right under the aerator, so if it is partly messed up is will cycle on and off every time you turn the faucet on, regardless of whether u use the spray or not, which can make that "clunking" noise
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Installing a new kitchen faucet... fp1 Plumbing 2 01-08-2007 07:02 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
