Kitchen Faucet Low Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2011, 12:48 AM   #1
Kitchen faucet low water pressure
2 yr. old Rohl kitchen faucet was making knocking sound when I turned it on, and was told by the company that the cartridge needed to be changed.
Removing the old cartridge was so difficult and stuck in so tight..only removed part of it. I was advised to pour 1/2 water and 1/2 vinegar to dissolve calcium deposits and to chisel or use screwdriver to remove it the rest. The original cartridge was a vacuum breaker unit.
Because I had to chisel it out there were many small bits of plastic and did my best to remove them from the opening holes on the mounting plate.
The new one to replace this model was different and it was called a brass sleeve non-vacuum breaker unit.
After following their instructions for installing the new cartridge, when the water was turned the pressure is low.....so low that pushing down for sprayer wouldn't engage.
I did remove cartridge twice and turn on both cold and hot water to see if any bits of plastic may be lodged, but nothing came out. I'm using it, but the pressure is low. The hot and cold is turned all the way open and it's still low.
Any other options to try?
apt238 is offline   Reply With Quote
Old 04-26-2011, 04:31 AM   #2
Rewards Points: 352
Get the correct cartridge?
plumberinlaw is offline   Reply With Quote
Old 04-26-2011, 06:21 AM   #3
Remove and clean the aerator screen on the tip of the faucet.
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (04-26-2011)
Old 04-27-2011, 12:52 PM   #4
It is the correct cartridge, that was my first thought also. I contacted the company and was advised to remove the cartridge and disconnect the lines from the hot and cold connections under the sink.
For 30 seconds pour water down and allow it to run into a bucket to dislodge any debris.
Another idea mentioned was to use an air compressor hose and blow into the lines to dislodge any debris.
Haven't tried these yet, but will give it a go this weekend.
I did remove the aerator and there was debris in it. This is a great tip.
It still has low water pressure and hopefully it'll get fixed this weekend
.......at least I can use my sink for now
Old 05-04-2011, 03:38 PM   #5
It's FIXED! After a couple more attempts, the lesson learned from this is that you need to check every part to be sure that it is free and clear of any debris.
After flushing the hot and cold tubings, checked aerator.......another suggestion was to check the pull out spray hose and disconnect and flush out the hose and the copper tubing. There was a great deal of debris in the copper tubing and after connecting everything back......................:thumb up: it worked and the water pressure is back to normal.
So always check all hoses, aerators to be sure it is clear.
The Following User Says Thank You to apt238 For This Useful Post:
plumberinlaw (05-05-2011)
No hot water out of my kitchen faucet JTapia Plumbing 12 01-01-2011 04:32 PM
Trouble with kitchen sink/hot water kid320 Plumbing 3 04-29-2010 10:31 AM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 03:16 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
