Kitchen Faucet Is Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2011, 01:09 AM   #1
Sycamore Inn's Avatar
Rewards Points: 87
Hi ~
Attached is a photo of my kitchen faucet with a pull out sprayer. I noticed water is dripping underneath the sink and it appears the faucet is leaking from the stem. I think that is the correct name. You can see the water stain in the photo around the stem. I was told the seal is worn out and it can be replaced.
Can this seal be replaced or do I need to replace the entire faucet? I don't want to replace the faucet right now until I upgrade the sink. A friend was helping me today but he was not sure if the faucet could be disassembled. He was trying to remove the faucet lever first with an Allen wrench and was having a hard time finding a wrench that fit.
Your thoughts?
Barbara
Sycamore Inn is offline   Reply With Quote
Old 10-02-2011, 07:58 AM   #2
DIY staff
Rewards Points: 7,174
Yes that can be rebuilt---Remove the handle---Turn off the water to the faucet----Remove the cap nut --pull out the cartridge---clean the valve body with some fine sand paper--lubricate the opening --add your new cartridge--cap nut and handle---
What brand is it?
Old 10-02-2011, 08:17 AM   #3
Rewards Points: 87
Brand is American Standard I assume I can purchase the replacement cartridge at Home Depot?? Does the faucet have a seal that requires replacement or the entire cartridge?
Barbara
Old 10-02-2011, 08:25 AM   #4
DIY staff
You are in trouble----Finding American Standard parts is damn near impossible---Get on the phone before you waste any gas----Sorry---Even my plumbing supply house will not deal with American Standard.
Old 10-02-2011, 08:38 AM   #5
DIY staff
This post is from yesterday---Leaky American Standard Connoisseur Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2011, 10:37 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Tee hee. ....... Ours sells it. You think they carry replacement parts for older stuff? ? ? :P
Journeyman Plumber
Old 10-02-2011, 11:09 AM   #7
Rewards Points: 87
Looks like you can find the part here: http://americanstandardparts.faucetdirect.com
Old 10-03-2011, 10:22 AM   #8
Rewards Points: 87
FYI - American Standard has a lifetime warranty on their faucets. I just spoke with the rep and she is sending me the cartridge and o-ring at no charge. If that does not fix the faucet then they will send me a new faucet - at no charge. The replacement part website is http://www.americanstandard-us.com.
Old 10-03-2011, 07:36 PM   #9
DIY staff
Thanks for the link-----and let us know how the service is after you parts arrive---
Old 10-08-2011, 01:22 AM   #10
Hello Barbara
please visit the following link: http://www.americanstandard-us.com/s...al.aspx?k=6310 you will find the faucet model number 6310 and some Installation sheets as well as some repair parts diagrams in the following link:http://www.americanstandard-us.com/a...Parts_1859.pdf. the fix is easy...but need to be done step by step / the repair parts diagram will help making the fix / . Basically: 1) remove the level, 2) remove the escutcheon cap, 3) replace the cartridg with seals and the o /ring (provided by AMSTD), it is pretty straight forward when following the diagram. Good luck
mrfix is offline   Reply With Quote
Old 10-08-2011, 04:27 PM   #11
Rewards Points: 87
Thanks. You're right that's the model number. The rep sent me the installation instructions and parts design via an attachment. She is also sending me the install kit with the allen wrench in addition to the cartridge and the o-ring. I hope this solves my leak
Old 10-08-2011, 05:12 PM   #12
Rewards Points: 87
Fed Ex just delivered my parts - o-ring, button and screw set, and the cartridge. Not sure that I want to attempt this myself but I guess I could give it a try.
Old 10-08-2011, 06:08 PM   #13
DIY staff
We are all still here if you have questions---Best luck--Mike--
Old 10-09-2011, 12:04 PM   #14
Rewards Points: 87
Hi ~
Ok I am trying diligently to get this handle screw loose with the allen wrench. It feels like the screw is stripped. Now what?
Old 10-09-2011, 12:20 PM   #15
Mark Potter's Avatar
Rewards Points: 150
Originally Posted by Sycamore Inn
Hi ~
If the screw is stripped then return the part u ordered and get new faucet cuz unless u drill the screw out not going to be the same trying to get a similar screw in
It's better to change out any faucet unless it's just the aerator it's just not worth the hassle.
H|P Capital
Mark Potter is offline   Reply With Quote
Two handle kitchen Faucet invisible screw: Leaking Faucet chicago7100 Plumbing 11 07-06-2013 01:14 PM
Kitchen faucet splinter2 Plumbing 1 01-13-2011 11:50 AM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Any advice on picking a kitchen faucet? ilyaz Kitchen & Bath Remodeling 2 02-08-2010 06:11 AM
