Kitchen Faucet Installation Dilemma - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2010, 01:38 AM   #1
Kitchen faucet installation dilemma
It's time to get a new kitchen faucet. I got a Moen (Renzo CA87316W). At installation time, I found out the two supply lines connectors don't match.
From the image below you can see my existing water supply line and the previous AquaTouch faucet both has 3/4" connectors. But the Moen supply line use a 3/8" compression fittings.
After some reading, it seems 3/8" compression fitting is very much the standard connection nowaday, (is that true?). If that's true then I don't have any choice but to get some kind of coupling to connect these lines.
But if there are faucets out there with 3/4" connectors then it's easier for me to install it.
What do you think a simple DIY like me should do ?
Nathan
nathan.tran is offline   Reply With Quote
Old 11-28-2010, 07:51 AM   #2
it is true, 3/8 comp is pretty much the industry standard. i would replace the two angle stops underneath the sink with new 1/4 turn ones that have a 3/8 comp outlet. not difficult at all, and you'll get the added security of reliable valves in case of emergencies
the_man is offline   Reply With Quote
Old 11-28-2010, 03:24 PM   #3
I got a faucet similar to my previous faucet with 1/2" inlet hose. Problem solved.
Nathan
No hot water in kitchen and dishwasher is not filling water lol Plumbing 3 09-07-2010 11:47 AM
Pulsating Kitchen Faucet Hemingway Plumbing 2 08-29-2010 03:03 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 06:54 PM
