[Kitchen Faucet] HELP!! Problem Removing Faucet For 3 Days.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2008, 09:23 AM   #1
Question
[Kitchen Faucet] HELP!! Problem removing faucet for 3 days..
I am sure some have encountered this...
(Please look at this pdf file: it is the T-shaped nut and bolt under the faucet)
http://www.pricepfister.com/website/...-072-01-p2.pdf
(this is not the model i have.. but for ease of explanation)
I just cannot remove this large nut that hold the faucet in place.
It is long nut bolted to the thread attached directly to main faucet body (under it).
I really think it corroded to the point that I will not be able to remove by turn it.
Is there a way to overcome of this "no way out" problem?
I tried spraying lub without any luck.
Then I thought about cutting sink near the main faucet hole and pulling old faucet out, but this sounds very.. damaging.
I would greatly appreciate anyone's input on this.
please.. somebody.. help me!!
Thank you! ^_^
yitbitw is offline   Reply With Quote
Old 04-09-2008, 10:00 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Basin wrench, and brute force, if it wont unscrew then it will snap under pressure.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-09-2008, 10:06 AM   #3
Post
I thought so too..
but the prob. is that the sink started to bend making popping sound.
I don't think sink is strong enough to do that..
Old 04-09-2008, 10:11 AM   #4
Journeyman Plumber
Try tightening it up 1st then try to back it off.
Old 04-09-2008, 12:06 PM   #5
Custom Cabinet Maker
if you can get a clean shot at it, try heating it. Just dont burn the house down around it :}
skymaster is offline   Reply With Quote
