Kitchen Faucet Has Low Cold Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2012, 01:04 PM   #1
aht
Kitchen faucet has low cold water pressure
Installed new kitchen faucet w/pull down handle and the cold water does not have as much pressure as the hot water. What can I do to fix this?
aht is offline   Reply With Quote
Old 11-14-2012, 01:53 PM   #2
Rewards Points: 24
New problem with the new faucet? Both supply valves under the sink open all of the way? Are the supply valves quarter turn ball valves or do they require full turns? If the latter, the cold water supply valve may hung up internally.
The Following User Says Thank You to DexterII For This Useful Post:
oh'mike (11-14-2012)
Old 11-14-2012, 02:22 PM   #3
DIY staff
Rewards Points: 7,174
Also---check for kinks in the cold supply line
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Low water pressure in kitchen faucet after replacing water heater SusanonDaffodil Plumbing 8 01-27-2011 02:28 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
