Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2012, 11:29 AM   #1
Kitchen faucet
We have a single stage faucet handle in our kitchen sink. Lately we are experiencing greater low pressure on the hot water side. We have to let it run for several minutes before it is as hot as we need it to be. The water heater is only two years old. All other areas when using hot water upstair
baths and down stairs bathroom it is normal pressure and water heats up in a normal time. Please any suggestions "In the cold in Omaha."
Thanks for the quit comeback. I live in the area of 138th and W. Center Rd. And, the faucet type is a Price/Pfister Series 532
Last edited by ahv5150@cox.net; 02-11-2012 at 02:09 PM. Reason: wish to respond to plummen.
ahv5150@cox.net is offline   Reply With Quote
Old 02-11-2012, 11:33 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What part of omaha are you in,what kind of faucet?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-11-2012, 08:48 PM   #3
kitchen faucet
Okay sorry for the late response. I live at 138th and W. Center Rd. The faucet is a Pfister/Pfizer Series 3523.
Old 02-11-2012, 08:58 PM   #4
plummen's Avatar
A couple things to check would be the pressure to the faucet and pressure out of the faucet.
Id shut off the hot water supply under the sink and remove the water line from the bottem of faucet itself and hold the end down into an empty bucket.
Then id turn the valve back on and see how much pressure you have,if you have plenty of pressure there id shut the valve back off and start looking at the faucet.
If you have low pressure coming from the hose Id shut off your water at the meter in your basement and replace the valve under your sink.
Is it a single or double handle faucet?
Old 02-11-2012, 09:35 PM   #5
Kitchen faucet
Thanks for the quick come back. It is a single lever faucet. I'll put your suggestions to work after mass tomorrow. Talk you then
Old 02-11-2012, 09:57 PM   #6
plummen's Avatar
Outdoor Kitchen and garage faucet plumbing plumlost Plumbing 7 11-09-2014 09:01 AM
kitchen faucet sudden stoppage amakarevic Plumbing 4 08-31-2011 10:47 AM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 12:08 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
