Kitchen Drain Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2007, 08:00 PM   #1
Unhappy
Kitchen Drain Leak
My leak is from the copper stub out. It is nothing big and non pressure so I am just looking for some insight as to what would be a simple fix.
I just went through a complete rebuild of my kitchen after a pin hole leak was found which damaged the sub floor and dry wall.
The wife thought it would be more cost effective to repair it all ourselves (myself ) and I am not about to remove the cabinets and drywall again if I do not have to.
The leak is from a crack (hairline) in the copper stub out (approx 1") so I was thinking of it could be an easy fix (I hope)
Any ideas?
Tom
Indianapolis
ITTTom is offline   Reply With Quote
Old 12-11-2007, 05:05 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You might be able to cut the line in the middle of that split and repair this with a slide-on neoprene rubber Fernco coupling the size of the drain pipe. A Fernco is a rubber sleeve with stainless steel clamps on both ends, and are code-approved for drain lines.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-24-2007, 08:18 PM   #3
Thanks Mike,
Went out that day found exactly what you discribed and worked like a charm.
Tom
Old 12-24-2007, 08:38 PM   #4
Long-Time DIYer
Great! Isn't DIY "fun" when it works. LOL
May you and yours have a very Merry Christmas and a Happy New Year.
Mike
Kitchen drain smell krtw Plumbing 6 03-07-2010 12:50 PM
Kitchen Sink Drain powrus Plumbing 4 12-06-2007 05:58 AM
Kitchen drain helpless handyman Plumbing 10 11-27-2006 07:37 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 07:07 PM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
