-   -   Kitchen Drain Leak (http://www.diychatroom.com/f7/kitchen-drain-leak-14279/)
ITTTom 12-10-2007 08:00 PM
Kitchen Drain Leak
My leak is from the copper stub out. It is nothing big and non pressure so I am just looking for some insight as to what would be a simple fix.
I just went through a complete rebuild of my kitchen after a pin hole leak was found which damaged the sub floor and dry wall.
The wife thought it would be more cost effective to repair it all ourselves (myself :furious: ) and I am not about to remove the cabinets and drywall again if I do not have to.
The leak is from a crack (hairline) in the copper stub out (approx 1") so I was thinking of it could be an easy fix (I hope)
Any ideas?
Tom
Indianapolis
Mike Swearingen 12-11-2007 05:05 AM
You might be able to cut the line in the middle of that split and repair this with a slide-on neoprene rubber Fernco coupling the size of the drain pipe. A Fernco is a rubber sleeve with stainless steel clamps on both ends, and are code-approved for drain lines.
Good Luck!
Mike
ITTTom 12-24-2007 08:18 PM
Thanks Mike,
Went out that day found exactly what you discribed and worked like a charm.
Tom
Mike Swearingen 12-24-2007 08:38 PM
Great! Isn't DIY "fun" when it works. LOL
May you and yours have a very Merry Christmas and a Happy New Year.
Mike
