-   -   Kitchen drain (http://www.diychatroom.com/f7/kitchen-drain-4991/)
helpless handyman 11-24-2006 07:38 PM
Kitchen drain
Hey Ron, hope your around!
I have a 2 inc pipe running on the right side of a window in the kitchen where I want to install my new kitchem drain. Its cast iron, and I am going to cut it, and replace it with sch 40. I have to use this pipe as drain as well as vent. My sink will be about 2 1/2 ft left from this pipe, how far up do I do the vent? Also can you draw a little skecth for me, and the pipes I need to do this? Thanks Ron.
Ron The Plumber 11-24-2006 08:31 PM
1 Attachment(s)
Is this what you want to see? That is a San-Tee 2" x 2" x 1-1/2"
helpless handyman 11-24-2006 09:19 PM
Thanks Ron, everything in the bathroom worked out lovely!!! I did a test on the tub drain today, and no leaks, and tub couldn't drain any faster! I also ran 3/4 inc water lines to both hot and cold as you recommended, and I got very good water pressure up there. Thanks so much for all your help!:thumbup:
Ron The Plumber 11-24-2006 09:20 PM
Like to see some finish pictures when you get time to take and post them
Good hear it truned out great.
helpless handyman 11-24-2006 09:24 PM
Thats exactly what I was looking for, I will then have to use a 90, since its running from stack to the left about 2 1/2 feet, then it has to come out of the wall to hook up a p trap. So I am looking at a san tee 2 X 2X 1 1/2, then a 1 1/2 90, then a 1 1/2 p trap?
Ron The Plumber 11-24-2006 09:26 PM
Yes correct.
helpless handyman 11-24-2006 09:29 PM
Thanks Ron, will definately post pictures in a few days!
helpless handyman 11-27-2006 03:17 PM
Whirpool Drain
Hey Ron, my whirpool drain has an extended tail piece that threads inside the drain assembly, fine thread. I just screwed it on and tested for leaks and didn't get any leaks. Should I remove it and put at least two turns of teflon tape on the threads, just in case? What to make sure, before I close the ceiling up!:laughing: Thanks
Ron The Plumber 11-27-2006 06:24 PM
Yes that or pipe dope.
helpless handyman 11-27-2006 07:33 PM
Okay Ron, can I use Real Tuff Pipe Dope? The thread on the pipe is very fine. Thanks
Ron The Plumber 11-27-2006 07:37 PM
Should do fine.
