Kitch Sink Faucet What Are These Screws For ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 04:16 PM   #1
kitch sink faucet what are these screws for ?
I am attempting to install a faucet the instructions are very poor -- I did a test fit and installed it with the washers in position as shown and the lock nut as shown but it seemed loose and not right. If anyone can verify-- the rubber washer would contact the sink (under) and then the metal washer and then the lock washer contacting the metal washer ? seemed not right
and also what are these 2 set screws for on the lock washer ??
thanks if anyone can help !!!
petros151 is offline   Reply With Quote
Old 07-28-2012, 06:16 PM   #2
Rewards Points: 582
that is the hold down washer and lock nut...after you tighten it up ..tighten up the set screws to secrue to sink top....
The Following User Says Thank You to ben's plumbing For This Useful Post:
petros151 (07-29-2012)
4" faucet OK for undermount bath sink? Homerepairguy Plumbing 2 01-14-2011 03:56 PM
Help replacing Kitchen Faucet (no nut under sink) deathandgravity Plumbing 5 12-09-2010 10:19 PM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 08:12 PM
What to do with short supply line for sink faucet? jon.french Plumbing 3 05-06-2009 09:22 AM
sink and faucet neo777 General DIY Discussions 8 11-05-2006 01:34 PM
