Kink In Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2009, 11:22 PM   #1
kink in pipe
Here is my situation.
I am redoing an old bathroom and have new copper pipe in the floor. While working I slipped and stepped on one of the lines. The is a slight kink where the copper went trough a joist, and a small bit of flex in the next 10' piece due to the slight bend. There is no leak. My question is do I need to cut this piece back out, or will it be fine since it is not leaking.
Thanks for your help.
Nick
nick nazz is offline   Reply With Quote
Old 02-25-2009, 04:48 AM   #2
Can you post a photo.... My wife once put "just a small dent" in my car
Chemist1961 is offline   Reply With Quote
Old 02-25-2009, 10:30 AM   #3
I would suggest repairing it now, while you have full access and no water damage. The kink has weakened the pipe and there is no way to estimate whether it will leak later.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-25-2009, 11:26 AM   #4
Registered User
Termite's Avatar
I agree 100%. Now's definately the time to take care of this.
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
