Old 01-14-2013, 05:08 PM   #1
kinetico water softener rebuild
Not so much a rebuild, but I need to fix it. It's a 10 year old softener r-60 I believe. It leaks around the base of the head and doesn't siphon like out should. I want to take it apart, clean it, and add new gaskets, even if it's just rtv. Does anyone have experience, advise, or a diagram?
Dwillems is offline   Reply With Quote
Old 02-09-2013, 11:41 PM   #2
I went ahead and took it apart and cleaned it. In the process I found a broken gear. Is there anywhere I can order the parts online? Or even find a parts diagram?
Old 02-10-2013, 12:27 AM   #3
Just Google the make and model.
Old 02-10-2013, 12:38 AM   #4
Ha, google it he says. I've tried a lot! That's why I asked here.
Old 02-10-2013, 01:07 AM   #5
http://www.kinetico.com/customer-support/
Old 02-10-2013, 01:20 PM   #6
Kinetico parts are available only from authorized dealers. Most dealers won't sell parts to individuals--only provide them as a part of a service call.
Because Kinetico is proprietary there are no secondary market parts and Kinetico doesn't make parts lists or maintenance manuals generally available to consumers--only authorized dealers.
Bob999 is offline   Reply With Quote
Old 02-10-2013, 01:44 PM   #7
Water Treatment
Any way of getting a photo of the part and where it goes?
I do have a box of Kinecito parts, and an older book, might be able to figure out what part and if it is in the box.
Akpsdvan is offline   Reply With Quote
Old 02-10-2013, 03:07 PM   #8
That's what i've read. I was really hoping someone had access to it though. Thanks
Old 02-10-2013, 03:10 PM   #9
Oh boy! I really hope you have this. It's a small, blue, plastic gear inside level 1. Has 28 teeth I think? Mine is broken. Plus i'm in need of one of those tiny E clips that hold those gears on. I have one missing. I got your pm, and will send an email today. Thank You!
Old 02-10-2013, 03:24 PM   #10
Water Treatment
Not a problem, been looking for a way of finding homes for the parts that I ended up with..
I know that I have some blue wheels with numbers on them, 1,2,3 .
Not sure about the E clips, going to need to see that to see if there is one in there.
Old 02-10-2013, 06:01 PM   #11
Thanks Akpsdvan for looking.
Unfortunately he didn't have the piece so i'm still trying to find this without an outrageous service charge from the dealer. So here is a photo of the gear that is broken if anyone can help me out. Plus i'm missing one of the small E-clips (i'm guessing that's the culprit for the broken gear).
Musty water from water softener tranders Plumbing 47 01-20-2013 02:37 PM
WHES40 Water Softener Water Meter Mudlvr Plumbing 4 08-18-2012 05:29 PM
Low water Pressure with water softener garden Plumbing 8 07-31-2012 02:03 AM
Culligan water softener not working (pics) Perm Plumbing 46 09-14-2011 01:29 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
