Kicthen Sink Woes.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2008, 10:12 AM   #1
Amateur DIYer
Kicthen sink woes..
Hi all;
I hope this is the right forum to post this is in...
I've just finished rebuilding my kitchen countertops (removed the old laminate counter, built up a new plywood/densshield base and installed tile).
I'm now trying to fit my sink back into the new countertop, but the old hardware I had (hold-down fasteners) can no longer work because my counter is too think now..
Here's the old fasteners I had:
To fit in this sink:
The old fasteners don't work because the slots they fit in no longer clear the bottom of the plywood (its too think now). I've since gone out and bought new hardware, and drilled some notches into the plywood.
New hardware:
notches:
But the new hardware, once tightened just pops out of the slots its meant to hold down.
Soo..... long story, but my question is, does anyone have any advice on securing this sink down. I've stopped and come on here, because I was getting caught in the trap of continuing to cut bigger notches in my plywood in order to try to make the old hardware fit, and I don't want to keep trucking along only to find out that I've made an irreparable mess!
Thanks!
Ben Z
bzarboni is offline   Reply With Quote
Old 03-29-2008, 10:20 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If they don't fit, does the rim of the sink sit pretty much flush to the tile top?
How about getting a new sink? A self rimming sink, or a different SS sink that has different mounting hardware that will work?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-29-2008, 10:24 AM   #3
Amateur DIYer
Hey there.
The sink sits mostly flush, except in one back corner. I'm only trying to reuse this sink only to keep costs down.. (this little project went a little over budget! )..
I'm also worried that the sink whole I cut would not fit a different sink..
Old 03-29-2008, 10:31 AM   #4
Journeyman Plumber
Set the sink without the clips, the trick behind this is you caulk the rim and let it dry, it should give a good enough adhesion on the edge.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Water from sink backs up in stack pipe. droy Plumbing 5 01-24-2008 07:39 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
