Kenmore Washer Will Not Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2010, 04:27 PM   #1
kenmore washer will not drain
hi i have a kenmore washer that will not drain after the agitate cycle. it is a direct drive type (no belt) and there seems to be nothing clogged anywhere, the waterpump spins freely and is not jammed or locked up. all I can think of is there is a problem with a switch or relay that engages the motor to turn on pump but i am not sure where to start. any help will be appreciated
hotrodbob is offline   Reply With Quote
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 10:46 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Kenmore washer won't drain. razburn Appliances 1 11-30-2008 08:25 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
