Kenmore Ulltrasoft 400 - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2011, 06:08 AM   #1
kenmore ulltrasoft 400
brine is not getting into the resin tank. I have tried everything i have found online to fix. there is a sucking sound coming from around the Venturi when brining but no water brine flowing in. I have cycled the backwashed about 10 times too. is it possible there could be a clog i have not tried? I have tanken appart and cleaned all the parts down to where the brine comes in the line.
DanOberhart is offline   Reply With Quote
Old 12-13-2011, 11:02 PM   #2
Water Treatment
Rewards Points: 848
Is the unit removing the brine from the salt tank area?
If the venturi is clear and there is no draw of the brine then there is a seal with in the valve that is bad and the valve body will need to be broken down and that seal replaced.
You might even need to replace the disc ..
Time and parts might be such that it is time to replace the whole unit with another cheap one like the one you are working on.
Akpsdvan is offline   Reply With Quote
kenmore water softener Squiddly Plumbing 6 11-16-2011 08:51 AM
Bradford White or Kenmore HWH? Durt Ferguson Plumbing 0 03-07-2011 02:54 PM
How much does it cost to operate my Kenmore freezer? sofasurfer Appliances 2 01-25-2011 01:46 PM
kenmore HE noise level boumans Appliances 0 07-16-2010 09:54 AM
Kenmore Icemaker install Turnerg110 Appliances 2 07-21-2008 04:55 PM
