Kenmore Elite Plumbing Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2010, 09:34 AM   #1
Kenmore Elite Plumbing question.
Hi there, I just bought a used fridge with "no known issues" :p I hooked up the water supply line and water leaks from the first unit that the water runs into. Can I bypass this piece safely, and wondered if anyone knows what it does?
The water supply looks as if it runs into this unit, then out of it, and into a Pur water filter, then into the door. Is it some sort of impeller to increase water pressure? does it chill the water on it's way to the dispenser? I am inept when it comes refrigerator plumbing. Does anyone have any ideas or recommendations?
I suppose I could remove the unit, silicone it, and hope that it doesnt leak down the road... but if I can bypass it without losing functionality it would make me feel more comfortable.
Thanks,
Spencer
skearton is offline   Reply With Quote
Old 05-04-2010, 09:28 PM   #2
Wow.... nothin?
Old 05-04-2010, 09:47 PM   #3
fabrk8r
fabrk8r's Avatar
Please check to make sure that the water supply line that you hooked up to the solenoid valve has the proper parts for the type of supply tubing you are using and is connected tight enough.
Try this link and see if it helps you understand the purpose of a water valve solenoid. If you have more questions let me know.
http://www.popularmechanics.com/home...umbing/1276061
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-04-2010, 10:06 PM   #4
That looks like the item I'm dealing with! Thank you so much for your help! It's amazing what some terminology can do to help me in my projects! Thanks again!
Old 05-04-2010, 10:14 PM   #5
and the water would flow continuously without this piece, correct?
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 04:40 PM
Question about plumbing project tx_kewlgurl Plumbing 1 01-09-2010 07:49 PM
Kenmore Elite refridgerator not distributing ice itr324 Appliances 0 10-16-2009 04:47 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Kenmore Elite Problems brittjon Appliances 1 11-10-2006 03:24 PM
