Kenmore Electric Waterheater Reset Button Trippin - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2012, 09:16 AM   #1
kenmore electric waterheater reset button trippin
why does evertime after a shower does the reset botton on waterheater trip and have to reset it is a kenmore power viser 12
allenn is offline   Reply With Quote
Old 02-16-2012, 09:27 AM   #2
Rewards Points: 13,752
http://electrical.about.com/od/elect...erproblems.htm
Old 02-16-2012, 09:28 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Could be an element starting to fail. Are there any signs of moisture around the connections?
Eventually the thermostat will not reset if this continues to happen.
How old is the water heater? May be time to replace the electronic components in it.
Journeyman Plumber
Old 02-16-2012, 09:53 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
If youíre talking about the red button on the thermostat thatís popping then you have a bad thermostat that is not shutting down. Lower or upper could be either one. Thatís a temper plate that detects heat only.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Heil HAC448AKC Reset button Bluebird HVAC 1 05-22-2011 11:50 AM
Oil Furnace want start after changing the filter and pushing the reset button pjsnipes HVAC 2 11-06-2010 02:28 PM
Push Button Switch for Electric Motor crmays Electrical 2 02-06-2010 06:29 PM
reset button db1020 HVAC 3 01-16-2010 04:36 PM
