Kenmore Doesn't Fill Properly - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2010, 03:11 PM   #1
Post
Kenmore doesn't fill properly
I have a Kenmore washer that works very good but recently, when it starts to fill back up for the rinse cycle the water just trickles in taking a long time to fill. At one point I was able to turn on the faucet (on high) in the deep sink next to the washer and eventually the water flow in the washer would return to normal but now, this doesn’t help and it takes a long time for water to fill the drum.
svcsupply is offline   Reply With Quote
Old 03-21-2010, 03:41 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
It sounds to me like (possibly) a calcium/lime buildup in your lines.
When it fills for the initial wash cycle, is the flow normal?
DM
Old 03-21-2010, 04:16 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Turn off the water supply to the washer. Remove hoses from back of washing machine. Look into the inlets. There should be a screen inside of the inlet, and it is probably clogged. Clean it out. Replace hoses. Turn on water. Proceed with the washin'.
Journeyman Plumber
Old 03-21-2010, 06:15 PM   #4
Rewards Points: 352
Hot, cold, both?
always or just sometimes
plumberinlaw is offline   Reply With Quote
How to fill this drywall gap? kupalino Drywall & Plaster 3 02-26-2010 06:45 PM
How to seal and fill sap veins before painting. fritzycat1 Painting 6 10-21-2009 12:13 AM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 10:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 09:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
