Kenmore 350 Series Water Softener Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2012, 08:12 PM   #1
Kenmore 350 series water softener problem
Hello, I was hoping someone could give me a little insight on an issue I am having. A while back the tank filled with water and after searching the issue I found that I had to clean the Venturi nozzle. The screen inside was caked in rust. I cleaned it, scooped all the water out of the tank and pressed regen. It seemed to be good for a couple days until I started smelling iron in the water again. The tank was filled again.
I have found that when it starts to regen it goes directly into a fill state and the LCD screen does not change to countdown screen showing the time left for the cycle. If I push regen again the screen appears and goes into a backwash state. I think when it goes to regen it goes to that fill stage and never goes any further.
Would anyone have an idea on what could be happening? I would greatly appreciate it.
Thanks!
Biggd is offline   Reply With Quote
Old 01-17-2012, 06:33 AM   #2
the venturi pores could still be clogged with rust. try using some redout or potassium permanganite (i think) to clean the rust inside the pores.
Hates my roof is offline   Reply With Quote
Old 01-18-2012, 08:30 AM   #3
Thanks for the info. I will look into how to clean it out. If there are any other ideas I would appreciate it.
Thanks !
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
kenmore water softener Squiddly Plumbing 6 11-16-2011 07:51 AM
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 08:17 AM
Culligan Medallist Series 45 water softener keithk Plumbing 3 08-25-2010 12:29 PM
