Just Installed NEW Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2009, 08:09 PM   #1
Just installed NEW water heater
Hello!
First off, I did punch "water heater" into the search bar and didn't find any relevant queries.
Anyways, recently I bought my first home. It came with a number of problems. Today I attempted to tackle the water heater.
First we went to Lowes and bought a new electric Whirlpool 28 gallon water heater. I live in a one bed, one bath place with only two people living here, so this small a heater I hope will be alright. It's nearly a direct replacement.
I've replaced it, with much more experienced help of course.
It has been in place, now, with a filled tank and a solid 238 volts at it for a little over two hours. I still have, at best, room temperature water.
Any suggestions? Am I being impatient for its first fill up?
Any help will be greatly appreciated, thank you!
Cpena is offline   Reply With Quote
Old 03-15-2009, 08:12 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Did you turn on the power to the WH before it was completely filled?
Old 03-15-2009, 08:15 PM   #3
Negative, ghost rider.
I waited 10 of 15 minutes after opening the water valve.
Old 03-15-2009, 08:22 PM   #4
Rewards Points: 560
If you are sure you have the hot and cold connections correctly I would look at the settings on the thermostats on each heating element. If they are set then I would turn off power to the water heater and disconnect one wire from each of the elements and check the resistance of each just to be sure that the elements are good.
Old 03-16-2009, 09:42 AM   #5
47_47's Avatar
Rewards Points: 58
Did you bleed the water tank (run the hot water) before turning on the power? The elements may not have been submersed and they may have burned out.
47_47 is offline   Reply With Quote
Old 03-16-2009, 05:45 PM   #6
You, sir, were correct.
Replaced them and I'm taking my first warm shower in almost two weeks.
This place has greet response times! Thank you, Plumber101 and 47_47!
Old 03-16-2009, 11:25 PM   #7
Rewards Points: 1,514
Water must be flowing from an open hot water faucet in the house and you should feel the pipes connected to the top of the heater vibrating slightly before you turn on the gas or electricity or burner.
AllanJ is online now   Reply With Quote
Change in pipe diameter at water heater blacksheiladog Plumbing 2 03-06-2009 12:12 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
Water heater hooked up backwards gfuterfas Plumbing 13 01-07-2009 08:34 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
